CSR (Windows 10 or Linux): "Failed to start Ganglion BLE..." / "Code 412 Error: TypeError..."
1. connect USB dongle
2. Win10 installs driver automatically (BTHUSB) - you can turn bluetooth on/off now and search for devices, but in the GUI you get "Failed to start Ganglion BLE Driver"
3. use zadig to install WinUSB driver
Problem:
Device is now listed under "USB devices" in the "device manager". Under devices there is no more option to turn on/off bluetooth. Therefore you cannot follow the following instructions.
Problem:
Make sure your computer’s Bluetooth feature is turned on. Select
http://docs.openbci.com/Tutorials/02-Ganglion_Getting Started_Guide#ganglion-getting-started-guide-start-using-the-openbci-gui-connect-the-gui-to-your-ganglion-board
Error messages remains: "Failed to start Ganglion BLE Driver"
LIVE (from Ganglion) from the first drop downhttp://docs.openbci.com/Tutorials/02-Ganglion_Getting Started_Guide#ganglion-getting-started-guide-start-using-the-openbci-gui-connect-the-gui-to-your-ganglion-board
http://openbci.com/forum/index.php?p=/discussion/comment/8275/#Comment_8275
a.) using different USB ports
b) restarting
1. close gui
2. close hub
3. deactivate csr8510
4. activate again
5. start hub
6. start gui
same error
no luck
I will plan to add BLED112 windows/linux dongle support when i get back into town next week. Seems there a number of people who want it
Thanks for driving feedback!
AJ
Opened OpenBCI_GUI as administrator.
Here are some questions :
Service"
CSR
Service Bluetooth Switcher
"Bluetooth driver management", but when I start it, a message tells me that the
processus starts and immediately closes.
Don't know if it is normal or if it could be related.
2) you said "Then, I launch Processing as an admin and load up my OpenBCI GUI sketch (version 3.3.1), And finally after hours of debugging, my Ganglion is detected."
I know nothing about "Processing", but
Maybe I could try to do the same, but with python. Don"t know if it is possible.it seems like you debugged a program (i.e. a "sketch") in
"processing". How is it
possible to call OpenBCI_GUI from a program. Do you know a link where it is explained ?
Anyways, thank you very much to anybody for any kind of help or even any response .
As in, use the built in Bluetooth hardware in Windows? I am running Windows 10 and could definitely use this! How would I test it?
Might also be worth compiling the GUI yourself in Processing. I do this since I had problems with certain features with the provided binary which were resolved when I compiled it myself.
Good luck to everyone. I spent weeks debugging so I know how frustrating it can be. I hope this problem is resolved for everybody shortly.
