Cyton V3 Firmware upgrade, detailed steps?
I have the daisy module attached and I am using the dongle (no wifi shield)
I am using Arduino 1.8.5
I have the following libraries installed:
Open_BCI_3bit_Library v. 3.1.1
Open_BCI_32bit_SD v. 2.0.0
OpenBCI_Wifi_Master 1.0.1
chipKIT v. 1.3.1
I am doing this on a mac
I follow the instructions here, under the heading "FIRMWARE VERSIONS 2.X.X & 3.X.X ... "
The first time I try to upload the sketch, I get a "no target found" error. So I use the radio config tool in the gui to make sure everything is on the same channel (from this thread). When I try to upload the sketch again I get another error message: "panic:runtime error: index out of range".
I have tried multiple orders of these steps: running the radio config tool, then opening arduino, then trying to upload the sketch as well as opening arduino, running the radio config tool, and then trying to upload the sketch. In all cases, I get a "no target found" for the first upload attempt and a panic runtime error for the second attempt.
If I try to verify and upload separately, the sketch verifies/compiles fine. When I click upload, we bypass the "no target found" error and go straight to the panic runtime error.
I hope this is enough info for someone to offer some suggestions. I'm not sure where to go from here in terms of troubleshooting. Any help is greatly appreciated!
