Help with commands to OpenBCI Cyton+Daisy
I am using OpenBCI Cyton+Daisy in combination with OpenVibe. In the Acquisition Server I can add custom commands that will be sent to the board to configure channels; and for that purpose I was following the instrunctions available on http://openbci.com/index.php/forum/#/post/discussion/cyton
For our BCI application we are using 12EEG channels + 1 EMG in bipolar configuration. However, i struggle to get proper EMG data.
First I turned off channels 13 14 15 by sending:
t y u
Then, I changed I want to change gain, remove bias and change to bipolar the last 16th channel. To do so, I was sending the following command:
xI040000X
To make sure that the I (16channel) is up, i also sent:
I
But I didn't get any signal on 16th electrode, only noise! The same configuration done via OpenBCI GUI works normally.
Thnx. Aleks
