SD Card saves Data without dongle Connection?
I have some problems with the stability of the bluetooth connection, especially if the participant is moving more than 3 or 4 metres away from the dongle. I know, I could use the WiFi Shield instead. However, another possibility would be to save data on the SD card.
My question:
- Once the recording was initialized and started via the GUI, does the SD-Card save all recorded data - *even if there is no bluetooth connection*?
- I guess the samplerate when using the SD is still 250 Hz, isn't it?
My question:
