Sample rate of 1kHz for EMG cursor control, How?
I'm trying to build a facial EMG device to control a cursor. The frequency range of EMG is between 20 and 500Hz. I would need to sample at 1kHz but I only need one channel. It seems that the limitations of the RF and Bluetooth don't allow real time with >250Hz. If I use only one channel, is it possible to increase the sample rate to 1kHz without loosing samples in real time?
I can't use the WiFi shield due to wifi limiations.
You should purchase a WiFi shield! This is exactly why we made it
https://shop.openbci.com/collections/frontpage/products/wifi-shield?variant=44534009550
There is also a 10% discount going on now
