How to become "DE - RAILED" ??
This thread aims at collecting tips on how to get rid of "railed" channels. (As displayed in OpenBCI_GUI.) Please, anyone, who has experience on that write a comment!
The GUI shows "Railed" when microvolt magnitudes for the channels are off the top end of the scale. In other words, generally it means something wrong with the differential voltage measured between the channel and the reference. Either one could have a poor connection leading to "Railed".
Help:
- Check wires.
- Check electrode contacts.
- Check connectors.
- Check board function: Connect SRB, BIAS, and railed Channel using jumpers / y-cables / ... This should give you roughly 0.00 uV. See picture (1).
1: https://drive.google.com/open?id=1VWtcAfGOxWQuRP6JoSkLQtwhT_LGXAmI
I spend roughly 45 minutes getting all channels de-railed. That's quite a bit more than the 30 seconds mounting time in the marketing video. When I released the headset and put it on again, it took me some other 30 minutes to get it run. Certainly, it needs some experience on how to best mount the headset. Could anyone please share his implicit knowledge? My goal is to make it in less than 5 minutes. Thank you.
Help:
- Check wires.
- Check connectors.
Greatly appreciate anyones help
The headset is new I got it in december
I will get back to you on impedance when I get home
Other people wearing the headset have the same results
Thanks @wjcroft I appreciate the help
I've tried running the software on both Windows and Linux
channels start railing and it takes a lot of times to adjust everything.
The adjustments do not last.
Any idea appreciated.
