Modify GUI Headmap Electrode Positions / Channels
Hi all,
I am currently working with p300 and would need to rearrange the electrodes positions.
Is there a way to specifiy these from the GUI or any documentation ?
Cheers
are the position of electrodes only relevant to the Headplot of the GUI?
If yes, is there an existing text file with all positions of the Mark4 headset model?
If no, what is to change on the board (cyton+daisy) nodes placement and the GUI?
Thanks a lot
I did not find a threat or tutorial on that issue. I figured out that the electrode positions of the headplot are adjustable by drag and drop. However, I have to do this every time I restart the GUI. Is there a way to save a chosen configuration?
Johannes
thanks for merging. The comment by @jussijaatinen actually effectively solves this issue. Just go to ~\OpenBCI_GUI\data than open the file electrode_positions_default.txt and change the settings according to your setup (You may wish to make a backup of the original file first). When starting the GUI, the head plot widget will always read out this file. It would be convenient, to know the coordinates of the other nodes of Ultracortex Headset, however by playing around one should get the right estimates oneself.
Johannes
