Battery on the 32 Bit Board
What kind of battery is used on the 32 Bit board?
  • The reason I'm asking is this:
    In the  OpenBCI store they say the input voltage for the board is 6-14V (see https://openbci.myshopify.com/collections/frontpage/products/openbci-32-bit-board-kit).
    According to the datasheet, the LP5907 regulator that is connected to the battery by diode D9 is rated for a maximum operating voltage of 5.5V with 6V the absolute maximum?
    The kit comes with a 6V battery pack, so that seems to be OK. What I don't understand is the 6-14V range for the input voltage.
    Hi Chessweb, it does look like you've found a typo.  Thanks.  I'll cc our webmaster and have the OpenBCI store page corrected.  The 6-14v figure was probably just copied over from the 8-bit board page.  That board has a 5v regulator sitting in front of all the other power related parts, and it is rated up to 16v input.  So on that board all the next level regulators are getting + or - 5v as their inputs.
    On the 32 bit board as you saw, an LP5907 (3.3v out) is sitting in front of the other regulators.
  • The two models of OpenBCI V3 have different voltage input constraints (sorry)
    OpenBCI 8bit Board has an Arduino UNO bootloaded ATmega328P, and operates at 5V (~50mA draw)
    Input to the OpenBCI 8bit Board is 6V to 12V.
    OpenBCI 32bit Board has a chipKIT bootloaded PIC32, and operates at 3.3V (~50mA draw)
    Input to the OpenBCI 32bit Board is 3V to 6V
