My Cyton board just stopped writing data to SD card. It initiates and you can see the data stream in the GUI, but no SD file is created. I tried multiple cards and none of them work. Has anyone else had this issue?
the version of gui 2.1.2 records correctly in the Sd card but the new verrsion 3.1 does not record any file into sd card by performing the same steps. I am doing something wrong?
I need the recorded files on the SD card, with correct time stamps recorded on the AUX channels.
the v3.2.0-beta2 is only for MacOSX and Win; v3.2.0-beta3 is only for MacOSX.
The source code does not seem for compiling on linux (what type of source code is this?).
any possibility to get the source code for linux ?
thanks
will try to run the source code with Processing under Linux unless somebody is kind enough to make a linux running version
https://github.com/OpenBCI/OpenBCI_GUI/releases/tag/v3.2.0
