SD card writing GUI v3.2.0 or v3.3.0 ?
ok, still problems with SD card writing/reading
1. is it possible to give access to all OS versions of the "beta" GUIv3.2.0 or v3.30 with correct SD card writing; not the "Processing" version... (at 2-5kB/sec for this website i cannot download from china...) I am interested in the linux version
2.
Is it possible to have all SD card commands available; i found that it
is possible to send 'echo -n 'X' > /dev/ttyUSB0' , and an 'N' command - see
https://github.com/OpenBCI/OpenBCI_32-write-to-DS-only - but i did not
find it in the documentation of OpenBCI Cyton SDK; furthermore, this 'N' command seems now to mean "write %STOP AT" .... from what i saw after SDcard file -> CSV file conversion ?!?
i am sending commands from a terminal through
simple "echo'ing" (for first tests) and succeeded to get SDcard files with GUIv3.1.0;
BUT with current "stable" GUI v3.1.0 when i convert the SD card
.TXT file to CSV it does not give the same numerical values as the ones
saved in the OpenBCI-RAW.....txt file in the SavedData/ directory.
what is wrong ?
i hope the SD card "stable" version can be rapidly fixed.
tzvetomir
2.
what is wrong ?
tzvetomir
IS NOT A RAW VALUE for the system i have: cyton+daisy 16 channels.
it is a "smooth"/mean of previous avlues and current measure, because of the limited bandwidth of the connection between dongle-cyton...
ok that is a 1st answer...
what about the GUI v3.2.0 or v3.3.0 ?
and ALL available commands for SD card ? i intend to use simple 'echo' commands for controlling the SD card params writing + time markers
when using the command /4 for changing the Board Mode to Marker Mode (http://docs.openbci.com/OpenBCI Software/04-OpenBCI_Cyton_SDK) what means:
"o 4 = Marker mode - Turns accel off and injects markers into the stream by sending `X where
Xis any char to add to the first AUX byte."What is the command for sending a marker ? Is it the character ` followed by some character used as time marker to put in the 1st AUX ?
trying them and closing this discussion.
