bad signals?
I have a cyton board with 8 electrodes. I have been trying to record some EEG data but I have some issues with the signals. First, I struggle to get the signals from all the electrodes (is it the case for some of you?). But also, when I try to treat/analyze the differents channels it is challenging because the signals are so noisy that I have to get rid of a lot of trials (sometimes the whole session). Those images are examples of some of my filtered data:
I have some mouvement artefact too everytime I ask the people to make a motor response (squeeze a dynamometer).
The best data I can observe is this (for instance):
Do some of you also observe noisy data like these ones? I don't really know what to do with it, should I just spend more time processing it or should I do something about the possible interference that I can have when I record? Is it related to the fact that I use dry electrodes? Are gel electrodes better?
Thank you for your help!
Hannah
Hannah
I use the Ultracortex Mark 4 EEG headset. The labels of the channels are correct. I don't know where the 100 uV signals may come from. Could it be movement artefacts?
I'll try to connect all channels, reference and bias together to see what I can get.
