RFduino radio firmware update with Arduino Uno? How?
khofstadter
Colchester, U.K.
Can I upload 'RadioHost32bit.ino' with and Arduino Uno instead of options here? If yes, any tips on how?
Also when uploading this code, the board needs to be on PC right?
I am having difficulties uploading with the OpenBCI dongle:
Sketch uses 0 bytes (0%) of program storage space. Maximum is 131,072 bytes.
expecting 14, got 46
Thanks! k
Thanks! k
I've tried several times, now I am considering soldering the pins to the board
Or could there be another reason for this message?
Thanks, k
This definitely means you are not holding them down. Try putting the pins through a header to make your life easier.
I've tried a few things, but no luck yet. Could you please check the video where I am trying to explain what I am doing - perhaps you can see the problem. Many thanks:
https://www.dropbox.com/s/3ftpsiamwc43qyz/openbci2.mp4?dl=0
