OpenBCI interface freezing when BDF+ file type is selected
Greetings,
I want to use the BDF+ file type so I do not have to convert the data in EDFbrowser to BDF for import into EEGLAB.
I am able to see a continuous data stream when the selected data type is OpenBCI, however when I choose "BDF+" the data stream will stop in the interface after some time.  When this happens, the interface continues to work - I can change anything on the GUI I want (Vertical Scale, the information presented in each frame, etc. etc.. The file size is relative to the amount of time before the data stream stops in the GUI.  I choose to stop the data stream, then I can STOP SYSTEM.  I then return to the GUI, where I can try again.  If I choose OpenBCI file type, then the system works without issue.
I have shut down my anti-virus, and etc.. (BitDefender).  Any suggestions?
Don
