are g.tec g.SAHARA dry active electrodes working with openbci?
i found SAHARA dry active electrodes here http://www.gtec.at/Products/Electrodes-and-Sensors/g.SAHARA-Specs-Features
is it working with openbci ? and is it give good clear signal ? and have u tested it?
http://www.gtec.at/Products/Electrodes-and-Sensors/g.Electrodes-Specs-Features
g.SAHARAbox appears to be battery powered, and with the "g.SAHARAboxCONNECTOR for g.BSamp", it looks like this would plug into standard EEG touchproof connectors on OpenBCI.
I'd love to see an update on pricing and how this works with non-g.tec EEG amps expecting passive sensors. It looks obviously compatible with their own passive amps. Cortech was the U.S. rep who sent me the quote. http://cortechsolutions.com/Products/DA
A better question might be addressed to g.tec, "has the g.SAHARA been used with other amps besides g.tec?". And "what is the cost per electrode? what is the cost of the g.SAHARAbox and connector for g.BSamp?" If you get those quotes, please post here, we're interested.
What kind of BCI do you do? What attracts you to OpenBCI as opposed to the g.tec equipment? Is cost a factor in your decisions? g.tec seems to be priced at the level that large corporate R&D departments can afford. But that is above most open source advocates' budgets. This might be changing as the market for consumer grade EEG is rapidly expanding.
Best regards,
