Noise & ~65hz interference
Hi all,
I am posting two questions here:
1) It appears that there is some noise in channels 3, 7, 10 (especially), 13, and 16. Does this look like noise or actual brain readings? I've been using the headset for a couple months now and I remember the headset showing all channels around 5-15uVrms. Looking back over my past recordings, it seems to have gotten worse over time.
2) There appears to be interference at 65hz. You can see I have the notch filter at 60hz so it shouldn't be from power lines. Is there something emitting a 65hz signal from a Macbook Pro?
Not sure if this is a valid thing to look at but I also put the headset on a flat surface near my Macbook and the front of the headset (closest to the Macbook) is showing some noise. When I move it away from the computer, the noise seems to disappear with the headset off of my head, but when I move away from the computer with the headset on I still see issues in the channels mentioned above.
I appreciate any help or tips.
Thank you,
Todd
I used a Frequency Counter that I purchased for $30 off the Internet and swept my apartment to find the best location.
Funny bit was - it was right where I was already sitting!
Don
Good catch! It is marketed as a Frequency Counter, but truly it is in fact an RF Meter. Sorry for not being more clear.
I was amazed at all of the RF generated by hydro lines hidden in the walls of my apartment. I found my stereo generating a significant amount of noise, but only if you were very close to it. I picked up a new monitor, to reduce on the amount of noise generated by my workstation, and moved my computer farther away from me.
Don
I just wanted something that basically detected signals - nothing too precise - I wanted to keep costs reasonable.
I picked up one of these for around $40.00 CDN:
https://www.ebay.com/itm/1x-IBQ102-Portable-Hand-held-Frequency-Counter-10Hz-2-6GHz-For-Two-Way-Radio-B1-/262969082025
I'm able to detect the signals generated by my monitor, hydro, stereo, cell phone, and etc... How accurate is it? Well, probably not perfect for $40. How good is the detection? Well, it is not using the best antenna considering all of the available frequencies that it detects. But does it work? YES!
Don
A question in general - if EMF noise plays a significant factor in this - would we benefit from wearing grounding straps? The body is a giant antenna, so if we were to ground ourselves via a strap, could that not eliminate stray electrical signals in our uncontrolled environments (meaning we are not in an electrically controlled environment and thus, subject to stray electrical signals)?
Don
