Florida Research dry electrodes corrosion, reaction, discoloration
Hey guys,
I'm about to complete my headset but I'm a bit scared to attach my electrodes. I read some users have experience corrosion even after one day when using them with stainless steel mounting.
Have any one experience this and are there any ways to avoid it?
Cheers!
Thanks for the photos.
Would still appreciate insights from @kzurn and @Conor
Where did you get your stainless bolts?
https://en.wikipedia.org/wiki/Stainless_steel#Types
EVEN the user who submitted that issue page, if they "used the parts listed" for the Ultracortex build -- could have wound up with bolts or oil coating that trigger this. Mechanical part suppliers get stock from many vendors. And do not have the same kind of chemical purity you would get with chemical grades,
Alcohol is likely not the best cleaning agent for coatings applied during manufacturing.
https://www.google.com/search?q=best+solvent+to+remove+oil
Thanks so much for all your solvent cleaning tests. It does now look like you have some kind of stainless steel alloy (as mentioned a few posts back) with a reactive element to the Ag-AgCl.
