"Failed to connect to data source..." after updating cyton to v3
edited September 2017 in Cyton
Hy,
I updated my cyton board to v3.0.0 rc6 using the arduino ide and built in library manager. Flashing the new firmware seems to working fine, but when I'm trying to connect the bluetooth dongle with the OpenBCI v3 GUI on Arch Linux and on all of my USB Ports I'm getting:
||             INITIALIZING SYSTEM             ||
OpenBCI_GUI: initSystem: -- Init 0 -- 896237
timeOfInit = 896237
OpenBCI_GUI: initSystem: Preparing data variables...
OpenBCI_GUI: initSystem: -- Init 1 -- 896238
Init FFT Buff – 0
Init FFT Buff – 1
Init FFT Buff – 2
Init FFT Buff – 3
Init FFT Buff – 4
Init FFT Buff – 5
Init FFT Buff – 6
Init FFT Buff – 7
OpenBCI_GUI: initSystem: -- Init 2 -- 896239
OpenBCI_GUI: initSystem: -- Init 3 -- 896239
  3a -- 896239
  3b -- 896239
OpenBCI_GUI: closing log file
cyton: openNewLogFile: opened ODF output file: SavedData/OpenBCI-RAW-2017-09-25_18-39-15.txt
ChannelController: createChannelSettingButtons: creating channel setting buttons...
8
Hub: processConnect: made it -- 896247
OpenBCI_GUI: stopRunning: stop running...
Closing any open SD file. Writing 'j' to OpenBCI.
comPorts = [/dev/ttyS0, /dev/ttyS1, /dev/ttyS2, /dev/ttyS3, /dev/ttyUSB1]
accel w 843
accel h 1244
accel x 1
accel y 109
widgets.size() = 10
widgetOptions.size() = 10
wm.widgetOptions.size() = 10
widgetOptions:
[Time Series, FFT Plot, Networking, Band Power, Accelerometer, Head Plot, EMG, Focus Widget, Pulse Sensor, Widget Template 1]
Powering 3 widgets up, and remapping.
Activating widget [0]
Activating widget [1]
Activating widget [2]
disconnecting serial
headPlot: computeWeightFactor: Ielec 0, solution complete with 2000 iterations. max_dVal = 2.000928E-5
headPlot: computeWeightFactor: Ielec 1, solution complete with 2000 iterations. max_dVal = 2.051592E-5
headPlot: computeWeightFactor: Ielec 2, solution complete with 2000 iterations. max_dVal = 3.4713747E-5
headPlot: computeWeightFactor: Ielec 3, solution complete with 2000 iterations. max_dVal = 3.489256E-5
headPlot: computeWeightFactor: Ielec 4, solution complete with 2000 iterations. max_dVal = 1.1825562E-5
headPlot: computeWeightFactor: Ielec 5, solution complete with 2000 iterations. max_dVal = 1.2218952E-5
OpenBCI_GUI: initSystem: -- Init 4 -- 897400
click
ControlPanel — port is open: false
initSystem yoo
When I send '?' with the ArduinoIDE my output is.
Board ADS Registers
ADS_ID, 00, 3E, 0, 0, 1, 1, 1, 1, 1, 0
CONFIG1, 01, 96, 1, 0, 0, 1, 0, 1, 1, 0
CONFIG2, 02, C0, 1, 1, 0, 0, 0, 0, 0, 0
CONFIG3, 03, EC, 1, 1, 1, 0, 1, 1, 0, 0
LOFF, 04, 02, 0, 0, 0, 0, 0, 0, 1, 0
CH1SET, 05, 68, 0, 1, 1, 0, 1, 0, 0, 0
CH2SET, 06, 68, 0, 1, 1, 0, 1, 0, 0, 0
CH3SET, 07, 68, 0, 1, 1, 0, 1, 0, 0, 0
CH4SET, 08, 68, 0, 1, 1, 0, 1, 0, 0, 0
CH5SET, 09, 68, 0, 1, 1, 0, 1, 0, 0, 0
CH6SET, 0A, 68, 0, 1, 1, 0, 1, 0, 0, 0
CH7SET, 0B, 68, 0, 1, 1, 0, 1, 0, 0, 0
CH8SET, 0C, 68, 0, 1, 1, 0, 1, 0, 0, 0
BIAS_SENSP, 0D, FF, 1, 1, 1, 1, 1, 1, 1, 1
BIAS_SENSN, 0E, FF, 1, 1, 1, 1, 1, 1, 1, 1
LOFF_SENSP, 0F, 00, 0, 0, 0, 0, 0, 0, 0, 0
LOFF_SENSN, 10, 00, 0, 0, 0, 0, 0, 0, 0, 0
LOFF_FLIP, 11, 00, 0, 0, 0, 0, 0, 0, 0, 0
LOFF_STATP, 12, 00, 0, 0, 0, 0, 0, 0, 0, 0
LOFF_STATN, 13, 00, 0, 0, 0, 0, 0, 0, 0, 0
GPIO, 14, 0F, 0, 0, 0, 0, 1, 1, 1, 1
MISC1, 15, 00, 0, 0, 0, 0, 0, 0, 0, 0
MISC2, 16, 00, 0, 0, 0, 0, 0, 0, 0, 0
CONFIG4, 17, 00, 0, 0, 0, 0, 0, 0, 0, 0
LIS3DH Registers
0x07 00
0x08 00
0x09 00
0x0A 00
0x0B 00
0x0C 00
0x0D 00
0x0E 00
0x0F 33
0x1F 00
0x20 08
0x21 00
0x22 00
0x23 18
0x24 00
0x25 00
0x26 00
0x27 00
0x28 00
0x29 00
0x2A 00
0x2B 00
0x2C 00
0x2D 00
0x2E 00
0x2F 20
0x30 00
0x31 00
0x32 00
0x33 00
0x38 00
0x39 00
0x3A 00
0x3B 00
0x3C 00
0x3D 00
Board ADS Registers
LIS3DH Registers
0x07 00
0x08 00
0x09 00
0x0A 00
0x0B 00
0x0C 00
0x0D 00
0x0E 00
0x0F 33
0x1F 00
0x20 08
0x21 00
0x22 00
0x23 18
0x24 00
0x25 00
0x26 00
0x27 00
0x28 00
0x29 00
0x2A 00
0x2B 00
0x2C 00
0x2D 00
0x2E 00
0x2F 20
0x30 00
0x31 00
0x32 00
0x33 00
0x38 00
0x39 00
0x3A 00
0x3B 00
0x3C 00
0x3D 00
When pushing the RST button on the board the output is:
$$$OpenBCI V3 8-16 channel
LIS3DH Device ID: 0x33
Firmware: v3.0.0-rc6
Regards
    Are you running the GUI as root (with sudo?) Linux seems to need that to access serial ports.
    Are you sure the dongle radio channel agrees with the Cyton mainboard radio channel? You are getting the serial connection to the dongle ok via Arduino IDE terminal. Unclear if the issue is the GUI, radio channel, firmware upgrade, etc.
    Can you try this same Cyton with Mac or Windows?
  • Thanks for your fast reply
    Starting the GUI as sudo and choosing manually channel 1 for the radio works for me, unfortunately now channel 1 shows a lot of noise and I can't bring it down when putting SRB, BIAS and CHANNEL_1 together.
    makuna
    Have you tried swapping around your electrode wires to eliminate the possibility of a noisy connector, cable, or solder joint? How are you "putting SRB BIAS and CHAN" together? With paste, with clips?
    All the other channels are working ok? Was this Cyton working on all 8 channels before the upgrade?
  • edited October 2017
    Hi please update to the 3.0.0 version with library manager!
