noise on certain Cyton channels
aarohi1510001aarohi1510001 Ghaziabad, Delhi
edited September 2017 in Cyton
I'm trying to fetch "closed eye" data by placing the electrodes on position o1 and o2. The cyton channels I'm using are 4 and 8, the problem which is arising that the data on channel 8 is coming fine but data on channel 4 contains lots of noise. I tried changing the channel from 4 to 2 but the same result.
Even I interchanged the electrodes from o1 and o2, ie. earlier o1 was connected to channel 4 and o2 to channel 8, but even after interchanging, it showed same results ie. noise on channel 2 and 4.
What should I do?
    What happens when you follow the exact steps in the tutorial, using paste and gold cups? Is the noise you mention above with gold cups or with a headset? Are your gold cups in good condition, no chips in the gold plate? Another test you can do is to paste all three or more electrodes together: channel, reference, and bias. This should produce close to zero microvolts.'
