GUI App non responsive when start system is clicked.
cohanbcohanb Sydney
edited August 2017 in OpenBCI_GUI
Hello I am new to the BCI world and am trying to start EEG scanning. I have setup all required hardware and software to instructions.
Testing Software with synthetic algorithm and works fine.
I am having problems with the headset connecting to the software.
I activate the USB and headset in the correct order. And when it comes to software, everything launches perfectly, I select my data source, USB etc then press START SYSTEM…
This is when nothing happens? The GUI application becomes un-responsive and no data is being seen in the greyAPP? I can not even press any other options on the GUI app.
Running Mac OS Sierra
  • Hi. Could you fix it? I have exactly the same problem.Thanks.
  • I also have the same problem. Anyone able to fix this issue? Thanks
  • I have same problem on linux, I get this stack trace in the console.. thx !
    ~/Downloads/openbci/application.linux64$ sudo ./OpenBCI_GUI
    libEGL warning: failed to create a pipe screen for i965
    Last update: 9/5/2016
    For more information about how to work with this code base, please visit: http://docs.openbci.com/OpenBCI Software/
    Graphics & GUI Library: ControlP5 2.2.6 infos, comments, questions at http://www.sojamo.de/libraries/controlP5
    attempting to load images for presentation...
    DONE loading images!
    java.net.ConnectException: Connection refused (Connection refused)
    at java.net.PlainSocketImpl.socketConnect(Native Method)
    at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
    at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
    at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
    at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
    at java.net.Socket.connect(Socket.java:589)
    at java.net.Socket.connect(Socket.java:538)
    at java.net.Socket.<init>(Socket.java:434)
    at java.net.Socket.<init>(Socket.java:211)
    at processing.net.Client.<init>(Unknown Source)
    at OpenBCI_GUI$Hub.startTCPClient(OpenBCI_GUI.java:12101)
    at OpenBCI_GUI$Hub.<init>(OpenBCI_GUI.java:12077)
    at OpenBCI_GUI.systemUpdate(OpenBCI_GUI.java:927)
    at OpenBCI_GUI.draw(OpenBCI_GUI.java:428)
    at processing.core.PApplet.handleDraw(PApplet.java:2437)
    at processing.opengl.PSurfaceJOGL$DrawListener.display(PSurfaceJOGL.java:849)
    at com.jogamp.newt.opengl.GLWindow.display(GLWindow.java:759)
    at com.jogamp.opengl.util.AnimatorBase.display(AnimatorBase.java:452)
    Instantiating hub object...
    Have you tried running the GUI as 'root'? For example, using the 'sudo' command.
  • yes I am running it as root
    sudo ./OpenBCI_GUI
    although I did have to change the permissions of the /dev/ttyUSB0 to get the Python library to connect ( as per the other forum thread )
    thx!
