Anyone versed in Linux that can help (Raspberry Pi 3)?
Hi all.
I've bitten a whole lot off and require a little (a lot of) help. I am a pretty quick study and usually get myself going on the net, reverse engineer a few things, get the idea and go! However, currently I have this insane wish to start using Linux (spurred on by my RPi), and am now not only neck deep in new command line material, but will be expecting my 16ch R&D kit in the post very shortly and want to use it with my Linux machine. I'm building it this week, and thinking to use Debian unless anyone suggests a good reason not to. It would be easier for me to use Windows, but apparently I like a challenge
Ultimately I would like to run it on the RPi3 if it's possible, and have seen the current thread running regarding that, and it's affiliated links to EEGHacker etc... I have exhausted all of these leads (and Google's) and still without answers to the following.
1. Is the RPi3 just not "grunty" enough? If not, i'll stop right there (for now). In my projects I do not want lagging of any live data for what ever reason, so my first logical port of call is to determine minimum specs for the OpenBCI_GUI_200_LINUX64 software. Can anyone answer that? The RPi3 has a 64bit ARMv8 1.2GHz Quad core, and 1G of RAM. Should I have more of any of that at the ready really?
2. If I get through the above step and it's suggested the RPi3 is a technically viable option, I should then proceed with figuring out how to install said software. I have got as far as downloading it to the RPi, and unzipping it in it's own folder even (achievement lol). But how do I install or "execute" the program itself? I'm just trying a dry run with the only Linux machine available at the minute, but also to get it on the RPi regardless would feel like a win to me too!
I have installed software with the basic Linux apt-get commands, but never installed software when provided a .zip like the Open BCI GUI for Linux. After unzipping, nothing seems obvious to this noob in Linux. Can anyone give any pointers?
Thanks
I only used Python 2.7 since that's what comes preinstalled on Raspbian, not sure if you'd run into problems with Py 3.
