Channel recording transiently locked to -0.1875V?
Hi folks,
Thanks so much for your previousd help with bringing the wired USB hack to Firmware 2.x. Wasn't sure if this belonged in a new thread because I don't know if it's related to the hack or not. In the meantime, I've tried reducing transient 60 Hz noise introduced by the nearby laptop and some of our setup, and I've had a ton of success actually building a faraday cage with aluminum foil, some copper wire shielding, and a cardboard box (happy to write docs on that too for the community). However, I've recently run into a bug that seems quite strange. Occasionally when I'm trying to record, the OBCI Node JS Server seems to believe that the channel set to recording is locked at -0.1875 V (which is also coincidentally the voltage recorded when I apply a test signal of ground). The part that seems strange to me is that the packets are otherwise intact so I don't think it's a problem with the connection itself. Here's a summary of the setup:
1) Subject: Rat with implanted screws resting on the surface of the brain. Soldered some of your touchless electrode cables to instead interface with an alligator clip that clips onto the screw
2) Electrode Locations: SRB attached to screw on the frontal lobe. Channel 1 attached to occipital lobe. BIAS Pin connected to needle embedded within the rat tail. These are considered literature values for EEG recordings in rats
3) Software: Using my modified Wired USB Firmware on the OBCI Board. Communicating using @pushtheworld 's NodeJS Server.
4) EMI Shielding: OpenBCI Board is placed within a small cardboard box wrapped in aluminum foil. Electrode cables are shielded with Copper Mesh sleeves. All conductive shielding grounded via breadboard. Confirmed that shielding are insulated from the electrodes otherwise
5) Description of timing of problem: Sometimes in the middle of a recording the recording will suddenly flatline at -0.1875 V. After that, then the device will continuously record that same value even after stopping/starting streamer, soft-resetting, and hard-resetting with power. When I try to record my EKG (SRB on one hand, CHannel 1 on the other hand), then the problem might be fixed. I usually try permutations of reconnecting and resetting and then the recordings come back transiently without any clear trigger of what caused it to work.
I've been having troubles because I am not quite able to create a set of conditions to reproduce this bug, and conversely finding a set of conditions that fix the bugs. I know that -0.1875V is also the value I get when I connect the cables to nothing, which I attribute to the EMI shielding blocking any transient signals. I was just wondering if you had encountered any similar symptoms before and/or have any tips on how I can go about troubleshooting this.
Thanks so much!
Cheers,
