PCB grounding
hi now i'm implementing the OPENBCI according to the schematic , i have an issue that i misunderstand ! should i connect -GND with AGND ? in other words should _GND be connected to the power plane ? as i see in the schematic -GND is not connected directly to AGND ?
another matter, could you please give us the PCB methodology and tips to achieve the project in a correct way ?
thank you so much
thank you so much
as you say yourself, _GND is not connected to AGND in the schematics. They are isolated from each other by the ADUM6010 chip.
I can send you the PCB layout i made and you can check out the <a href="http://buildandcrash.blogspot.de/2013/12/eeg-design-time-for-something-totally.html" title="this one"></a>
Rick
