toggle menu
OpenBCI Forum
Sign In
Register
Sign In
Register
Categories
Discussions
Activity
Sign In
Register
Home
Software
Midi-Audio Output section in BrainBay
emiro
March 2017
edited March 2017
in
Software
Hi, I am running Windows 8 with LoopBe30 installed but BrainBay display in Midi-Audio Output section only "Microsoft MIDI Mapper", should display also "Internal MIDI 1" defined by loopbe30?
wjcroft
Mount Shasta, CA
March 2017
The Microsoft MIDI mapper should produce sound through your audio device.
emiro
March 2017
I would like to route the MIDI from BrainBay to the "internal MIDI 1" defined by LoopBe30 and then to DarkWave Studio. Is it possible?
wjcroft
Mount Shasta, CA
March 2017
Look around for apps that might let you reroute audio or midi streams.
Source for BrainBay is available, you could fix the bug or add that capability.
https://github.com/ChrisVeigl/BrainBay/blob/master/src/midi.cpp
https://www.google.com/search?q=windows+reroute+midi
http://coolsoft.altervista.org/en/blog/2013/03/what-happened-midi-mapper-windows-8
It looks like LoopBe30 is one such.
emiro
March 2017
Ok thanks, I am using LoopBe30 and works ok with BioExplorer, it
recognize "01 Internal MIDI" created by LoopBe30.
I will try to look the code but unfortunately I am not an expert.
Sign In
or
Register
to comment.
