time stamp not increasing, aux data interleave, binary output
Here is the raw data I got with 8 channels. My questions are
1: if sample rate is 250Hz, I expect the time stamp will in 0.004 step, but it seems not, why?
2: for the last 2-4 collum, it is: Accel Data (in G) interleaved with Aux Data? may I know what is the meaning of interleaved with AUX Data?
3: Is it possible to save it in binary to save file size and reduce wireless traffic?
Thank you very much!
%OpenBCI Raw EEG Data
%Sample Rate = 250.0 Hz
%First Column = SampleIndex
%Last Column = Timestamp
%Other Columns = EEG data in microvolts followed by Accel Data (in G) interleaved with Aux Data
0, 75561.05, 64046.38, -187500.02, -187500.02, 46287.06, 46024.03, 46088.63, 64357.91, 0.016, 0.474, 0.114, 12:30:54.403
1, 75540.76, 64015.62, -187500.02, -187500.02, 46587.18, 46188.85, 46114.80, 64292.18, 0.000, 0.000, 0.000, 12:30:54.883
2, 75085.32, 63538.88, -187500.02, -187500.02, 46615.46, 46460.29, 45689.04, 64611.76, 0.000, 0.000, 0.000, 12:30:54.884
3, 74793.98, 63247.59, -187500.02, -187500.02, 46317.13, 46468.63, 45363.09, 64885.01, 0.000, 0.000, 0.000, 12:30:54.884
4, 75086.05, 63556.58, -187500.02, -187500.02, 46099.87, 46181.70, 45600.33, 64711.41, 0.000, 0.000, 0.000, 12:30:54.884
5, 75568.36, 64039.73, -187500.02, -187500.02, 46286.95, 46017.30, 46072.11, 64330.53, 0.000, 0.000, 0.000, 12:30:54.885
6, 75551.42, 64017.56, -187500.02, -187500.02, 46598.31, 46184.67, 46105.88, 64257.84, 0.000, 0.000, 0.000, 12:30:54.885
7, 75091.38, 63544.78, -187500.02, -187500.02, 46615.19, 46453.54, 45664.03, 64578.17, 0.028, 0.936, 0.228, 12:30:54.885
8, 74852.21, 63312.16, -187500.02, -187500.02, 46351.35, 46482.86, 45386.29, 64852.54, 0.000, 0.000, 0.000, 12:30:54.886
9, 75167.91, 63648.67, -187500.02, -187500.02, 46168.55, 46229.98, 45658.82, 64698.06, 0.000, 0.000, 0.000, 12:30:54.886
10, 75657.39, 64148.92, -187500.02, -187500.02, 46366.32, 46085.83, 46147.37, 64334.53, 0.000, 0.000, 0.000, 12:30:54.886
Yes, AUX data is interleaved so as to make space for your own AUX info if you have some.
I saw that eventually EDF / BDF output format for the GUI will be supported, not sure the timeframe. Wireless data IS binary already, this is just the GUI output in text format.
2. correct. The Accel values are only inserted every 'n' EEG samples. The other slots (shown as zeros) could conceivably be filled with your own AUX data, if you wrote custom firmware.
3. I said 'eventually' GUI will output EDF (16 bit format) or BDF (24 bit format). As I said, I don't know when this is expected. It could be one of the upcoming GUI Widgets that Gabe is working on. See the thread about LSL Widgets.
