How does one use the Arduino IDE to program the Simblee microcontroller on the Ganglion? I'm currently having trouble getting my computer to find the Simblee microcontroller. Is a usb shield required?
I bought the ganglion in order to learn how to make BCI systems to control the external environment. My beginner project is to turn on an LED with EEG signal. Would modifying the Simblee microcontroller be the best way to do this or is there another way?
@allenine, hi. The easiest way to control external hardware is with a separate Arduino on a serial USB COM port. Your EEG reading program can send control commands out that COM port. See Chip's blog for some examples,
How does Chip send his processed EEG information to his Arduino? Is it using the processing software or some other software like MatLab? Does anyone have any tutorials dealing with this? I've been looking around his blog for a while but have been able to find something specific. Thanks!
Please look through the links I sent above. He uses a modified version of the OpenBCI_GUI program. You can make such mods yourself. For example, he detects when the alpha band is present in the FFT graph, then sends commands out the serial port to the Arduino to control the hexbug.
Hi, I just wanted to know if it's possible to program the Ganglion as an Arduino. In particular I need to use the digital pins. I saw the GUI software but I don't wan't to use that as for my purposes there won't be a computer "in the middle"..I found some libraries on github but I'm not sure they are what I'm looking for and I'm a bit confused about the docs on the website. Can anyone show me what I have to use?
Hi @wjcroft and thank you. I'm not sure I understood what's the upcoming tutorial about. What I'd like to know is if I'd be able to manipulate the eeg data directly on the board and send them to the output pins..basically like normal signals in arduino, without having a computer or other software in the middle. Basically like for the Cyton http://docs.openbci.com/Hardware/05-Cyton_Board_Programming_Tutorial Is this what's the tutorial will be about?
You could look at his code and replace the radio feedback with direct output to the pins, for example to control LEDs or sounds via piezo speaker, etc. Github link is there on the page (for Cyton).
Hi, do you have a time frame for the Simblee programming tutorial. I downloaded CSR BlueSuite and still the Arduino IDE doesn't find any port for the CSR dongle.
Please don't just ignore us.We wanted so long to get the Ganglion shipped, psychologically it's hard to accept to have no doc available and to be forwarded to an irrelevant one.
Please give us at least a honest time frame at least for the docs. We want to reprogram to Ganglion since we cannot count is a straightforward serious and hackless solution for now.
I know that your job is hard as most of us but communication is king if you want to make friends.
Hello, can any of you guys tell me how to send for example the alpha waves to an Arduino. I want to control a servo, how can i tell the servo when to move based from openbci gui
@Ahmed2205, see the previous posts above on how Chip did this with the Hexbug demo. Alpha detection is most easily done in the laptop, which can then send commands to a separate Arduino on a dedicated COM port. The commands sent on the COM port to the Arduino then control your servo operation. Don't try to control a servo from the Ganglion or Cyton boards directly, this is too much noise and will overwhelm your EEG microvolt signals.
Some 'widgets' are under development for the GUI, but I'm not sure the timeframe. Best approach might be to browse Chip's Github for examples. You will need to adapt his code and merge into the current GUI code.
Yet another way to detect band activity is to use a VPL, such as OpenViBE, BioEra, Bioexplorer, etc.
This current thread is concerning Ganglion board programming. So best to continue your discussion on a more appropriate thread.
Both Bioexplorer and BioEra now support Cyton and Ganglion. Check with the respective websites and contact the developer, a beta test version may be available.
Addendum to the comment on Cyberevolution / Bioexplorer: we have no idea when the Bioexplorer will be released with the Cyton driver. Larry claims it works in house, but is not responding to emails asking for a link to the beta. As far as Bioexplorer support for Ganglion, that looks even more up in the air. Larry said one issue was that Windows 7 has no Bluetooth Low Energy support. This is one reason the OpenBCI GUI requires use of a BLE dongle for Ganglion: either the CSR or the newer BLED112. BioEra uses BLED112, so this looks like the best option.
If you want a VPL with Ganglion, BioEra is your best bet at the moment.
Hi everyone,I am using Ganglion Board for EEG measurement. I am trying to program the ganglion board OTA. I will list out the steps followed: 1. Installed compatible version of Arduino IDE(1.6.10) with Simblee Arduino IDE Library Files(1.0.3) 2. Followed the steps given on: https://github.com/OpenBCI/Docs/blob/master/Hardware/09-Ganglion_Programming_Tutorial.md 3. While compiling the Default Ganglion.ino file, this error comes
Compilation Error: recipe.preproc.macros pattern is missing
I have some questions in my mind. Is it possible to program the simblee OTA using windows? Do we require the wifi shield along with the Ganglion board for OTA Programming? Isn't that possible using Simblee BLE?
Please help me out to compile the code and answer these questions.
We are not able to create the file with windows yet. This process works with Macs to create the appropriate zip file, then you can use iPhone or Android to do the OTA upload.
Alternatively, you can use the wired programming scheme at the end of the tutorial.
Thanks a lot biomurph for the valuable information. Please help to compile the code (Compilation Error: recipe.preproc.macros pattern is missing), this is the error that pops up.
http://docs.openbci.com/Hardware/09-Ganglion_Programming_Tutorial
Michael
https://www.google.com/search?q=eeghacker+hexbug
Thanks
B.
What
Here's Hassan's AlphaWave project, which runs on the mainboard, and does feedback over BLE to a phone,
http://openbci.com/forum/index.php?p=/discussion/691/openbci-alphawave-bluetooth-le-enabled-no-dongle
Thanks
Thanks for the reply if there is any.
This suggests that Bioexplorer works with openBCI hardware. I see no evidence of that yet.
Best regards,
Michael
As far as expecting support from the developer... well, you must not have much experience with Bioexplorer.
Best regards,
Michael
Thanks
