Really bad noise only when I am connected.
I have been testing some suggestions since not being able to update to V2 which is described in my last thread.
http://openbci.com/forum/index.php?p=/discussion/954/uploading-v1-v2-firmware-read-page-failed#latest
WJCroft suggested to try by attaching 1 channel and pasting the bias and srb2 together with it. When I do this, I get no noise, it shows correctly when I touch my finger on the electrode and activity shows on the data stream but not the head, everything looks like the screenshots provided in the getting started guide. As soon as I connect my self with the same channel, the data goes absolutely crazy. Can anyone suggest anything to try please, screenshots as bellow, I have also tried the same with channel 2 and channel 7 with the same results:
Connecting channel 2 with bias and SRB2
With me connected:
With me connected:
This is a bit better than my original thought the device was broken, looks it is just me that is broken
Thanks in advance for any advice.
With all that gear it seems like you should be able to borrow a friends laptop for a test outside your lab.
It's a matter of degree. Most locations are fine. Some have excessive noise. What location were you in for your previous tests that worked last year? If it was the same as this one, then I'm stumped. What has changed since then? Sometimes fluorescent light ballasts or other power supplies can go bad, spewing out EMF in all directions. If you had an EMF meter there you could sniff it out see what is spiking the 50 hz noise.
https://www.google.com/search?q=emf+meter
https://www.google.com/search?q=emf+meter+app
Your noise could be coming from a conduit under your floor or wall, power bricks, etc.
Cheap Windows laptops can be had for $200 these days.
Another test to reduce noise level is to put the mainboard / battery in a shirt pocket, then use a clothespin or similar clamp to route the cables over your shoulder and onto your head. This reduces cable motion, which can also cause artifacts.
Cable length makes a difference as well, the shorter the better. If you look at the Ultracortex photos, the cables there are each less than one foot and go directly back to the mainboard. This cuts noise.
