detecting 150 and 200 Hz in GUI
I have using processing files of HexBug experiment from Chip. It was great help from chip by providing the files through GITHUB. I am doing similar kind of stuff. I have few doubts:
1. If the sample rate is changed from 250 Hz to large frequency, which other files I need to take care?
2. My peak detection frequencies are 60 to 70 Hz and other will be 150 to 200 Hz. What files I need to take care other than EEG_Processing?
3. Do I need to change the filters in the EEG_Processing file?
Can anyone guide me on this?
Many thanks.
2. Google "nyquist limit". You need at least 2, preferably more samples per sample wave period. 250 Hz can at the most get you 125 hz waves, but better with 3, 4 etc samples. So 80 hz. Even then you'll hit aliasing effects. EEG above 50 hz or so is mostly EMG artifact, not EEG.
3. Filter coefficients can be changed.
http://openbci.com/forum/index.php?p=/search&Search=coefficients
