New on the forum / neurofeedback?
originorigin London
edited December 2016 in Software
Hey,
I was following the forum for quite some time, and I must say that I probably know 0 about most of the discussions here. I am interested in neurofeeback and how to balance my over active brain. I have completed 20 days of neurofeedback training using LORETA, and I was diagnosed with TBI. The sessions were expensive, but I did get some results, both seen on the brain map and in life.
I am eager to practice neurofeedback on a daily basis to treat the symptoms I have, and have a more balanced peaceful brain. I was reading in the forum to find an answer to my questions, but I have encountered really advance discussion. My questions are : Is Openbci hardware and software at stage where a newbee can implement protocols to help treat his symptoms ? If it is, is there anyone that can help me getting familiarised with the software and how to implement the best protocols for my case ? (With payment of course).
All the best.
  • Thanks @wjcroft, I have read through the discussion and it does sound interesting. I do hope that OBCI will become more end user oriented in the future, with 1 on 1 guides on how to use it affectivley with NM or any other software protocols. The company I have worked with mentioned that at this point I can use a 4 channel eeg to continue with my progression. Hope it will be affective as the 19 channel was, it sure left me hungry for more.
    I don't mind diving into the technical realm of OBCI, and buying a unit if I can actually progress with my treatment without doing any damage. Before doing so, do you believe that OBCI is in that stage where an unxprience user can create good protocols for his/her symptoms ? Will I need 1 on 1 sessiosn in order to set up the protocols on any given software ?
    Thanks in advance.
    Your best bet for home training is with Pete Van Deusen's Brain-Trainer system. Link at the NeuroBB thread.
    To do home training you really need to do periodic assessments / brain maps. Otherwise you are flying blind. It was hoped that Ganglion would be supported for Bioexplorer and the Brain-Trainer protocols. But that seems to have taken the back burner at the moment. May pick up next year. For now, Pocket-Neurobics gear is reasonable.
