error at running 64bit OpenBCI_GUI.exe
Hello OpenBCI community,
I am attempting to install a OpenBCI 32-bit Board Kit that I purchased October 2014 for the first time - I know, a tad late.
I am running OpenBCI_GUI.exe for 64bit on my 64 bit computer, but the window opens and closes fast creating an error log. I am attaching below the beginning and end of the log.
Is this a common error that you can pattern match? How to proceed?
Thank you,
Nicoara
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000018008cce9, pid=9920, tid=6376
# JRE version: Java(TM) SE Runtime Environment (8.0_51-b16) (build 1.8.0_51-b16)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.51-b03 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [ig4icd64.dll+0x8cce9]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x000000000c3c2000): JavaThread "main-FPSAWTAnimator#00-Timer0-FPSAWTAnimator#00-Timer1" [_thread_in_native, id=6376, stack(0x000000000ee50000,0x000000000ef50000)]
siginfo: ExceptionCode=0xc0000005, writing address 0x0000000122f561e8
VM Arguments:
jvm_args: -Djna.nosys=true -Djava.library.path=C:\Users\Nicoara\Downloads\application.windows64\application.windows64\lib
java_command: OpenBCI_GUI
java_class_path (initial): lib\OpenBCI_GUI.jar;lib\core.jar;lib\jogl-all.jar;lib\gluegen-rt.jar;lib\jogl-all-natives-windows-amd64.jar;lib\gluegen-rt-natives-windows-amd64.jar;lib\jl1.0.1.jar;lib\jsminim.jar;lib\minim.jar;lib\mp3spi1.9.5.jar;lib\tritonus_aos.jar;lib\tritonus_share.jar;lib\jssc.jar;lib\serial.jar;lib\controlP5.jar;lib\gwoptics.jar;lib\gwoptics_fake.jar
Launcher Type: SUN_STANDARD
Environment Variables:
USERNAME=Nicoara
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 42 Stepping 7, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 7 , 64 bit Build 7601 (6.1.7601.18798)
CPU:total 8 (4 cores per cpu, 2 threads per core) family 6 model 42 stepping 7, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, aes, clmul, ht, tsc, tscinvbit
Memory: 4k page, physical 8280236k(3151664k free), swap 16558620k(10368844k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (25.51-b03) for windows-amd64 JRE (1.8.0_51-b16), built on Jun 8 2015 18:03:07 by "java_re" with MS VC++ 10.0 (VS2010)
time: Mon Nov 28 18:31:45 2016
elapsed time: 6 seconds (0d 0h 0m 6s)
https://forum.processing.org/one/topic/libraries-must-be-installed-in-a-folder-named-libraries-inside-the-sketchbook-folder.html
