Problem obtaining EMG data from text file
in OpenBCI_GUI
I am currently trying to use OpenBCI to relay EMG data to a c++ software, by having it read the generated text file. In the GUI, I can get good results by setting up a filter from 15 to 50 Hz, and using the wrist as a SRVB signal (bias not added). I can also read the data from the .txt into my software without problems.
However, I have not been able to get any meaningful information out of the text file. I have added a high-pass filter into my file to get rid of the offset, as well as a rms conversion over 50 data points (added after the filter), but after passing through the high pass filter, the signal suffers no difference from EMG activity. Results after the rms conversion tend to stay between 10 and 11 uV for the biceps braquealis measurements regardless of it's position or what else is shown in the GUI.
From my understanding, after adding a low pass filter and converting it's value to rms, I should have obtained a signal that can actually be used to determine muscle activity. Is there anything I am missing, or that I might be doing wrong?
