v2 firmware and GUI stability
tektek Sweden
edited October 2016 in OpenBCI_GUI
I would like to make some modifications to the firmware, and in the long run it would obviously be best to use the latest code on OpenBCI_32bit_Library. But I'm a bit unsure, is this code reasonably stable? My biggest worry is bricking the board, as that would be a rather expensive mistake... Furthermore, is the GUI usable with this version since, as I understand it, the protocol has changed. I guess OpenBCI_GUI_2.0 is used for this?
I'm also assuming the repo OpenBCI_32bit will be deprecated and shouldn't be used if I'm going with the new firmware, is this correct?
On a related note, has anyone had any success with setting up an (maybe an QEMU based) emulator for the chipKIT system? It would be really nice to develop against that firsthand, but it is probably a lot of work to configure it to emulate the OpenBCI system.
    Including AJ Keller @pushtheworld
    My understanding is that the data stream output from the V2 firmware is the same as V1 firmware. Thus works with both V1 and V2 GUIs. The V2 firmware is shipping on all new boards sent out from fulfillment.
  • Hey @tek (thanks for mention @wjcroft)
    Yes it seems to be pretty stable. I've been using it and am getting good data and such.
    This is impossible and you can always install the older versions of the firmware if any problem arises.
    The old GUI is totally usable. Don't use OpenBCI_GUI_2.0 yet, it's still in beta.
    It should be deprecated, see https://github.com/OpenBCI/OpenBCI_32bit_Library/tree/master/examples for examples of different configurations.
    No! If you figure it out, please please tell me how!
    I use https://github.com/PushTheWorld/PTW-Arduino-Assert to do my automated tests for the system.
    Be sure to check out the section called References which has a bunch of useful links and learning resources.
  • Alright, I'm making some progress!
    I have succesfully changed the firmware now to v2, and written a small python script to collect data.
    But sometimes I get corrupted packets, which might be due to me not upgrading the radios.
    Before I try to reprogram them, I just want to check if someone here knows more...
    The
    streaming format is supposed to be the same, but for example, on the
    master branch, in OpenBCI_32bit_Library.cpp:824 it begins all packets
    with an 'A' instead of 0xA0:
    Serial0.write('A'); // 0x41
    This
    obviously breaks backward compatibility, but if I remove it, I can get
    things to work again. Then it also only writes 32 bytes which seems to
    be good for radio packet alignment. But for some magical reason, the
    streaming packet header '0xA0' is appended too, which I assume must be
    done by the RFduino firmware somehow. This also makes me believe that
    the RFduino firmware might have a misunderstanding with my v2 OpenBCI
    firmware, which causes my packets being corrupted, but I am still
    investigating.
    For example, here are one packet that is valid, then directly after follows an invalid packet:
    VALID     id: 86 raw: [86 83 c0 f5 85 2a b0 84 68 25 84 ce 25 83 94 b6 84 2f 50 85 21 ca 84 ba bf 00 00 00 00 00 00 c0]
    INVALID id: c0 raw: [c0 87 84 1e eb 83 fe b1 83 6e a5 84 8a 61 83 b9 40 84 a4 69 82 ed 59 83 8e bd 00 00 00 00 00 c0], expected id:87)
    As can be seen, the end marker is read again in the beginning of the following message.
    My question is, do the radios know stuff about what's being sent, and do they modify the data being sent?
  • In short, yes, it matters very much with firmware v2. All three micro controllers should be updated.
    Please read the tutorial below:
    http://docs.openbci.com/tutorials/04-Updating_Custom_Firmware_to_2.0#updating-and-using-v200-32bit-firmware-sending-data-packets-from-the-pic32-to-the-pc
