Connect Ultracortex Electrodes to Daisy Module
I soldered some header pins to my OpenBCI 32bit Board and Daisy Module. Do I need to connect some of the electrodes from the OpenBCI Ultracortex Mark III "Supernova" to the Daisy Module? I'm not sure which color electrodes go to which pins on the Daisy.
http://docs.openbci.com/headware/01-Ultracortex-Mark-III-Nova-Revised#ultracortex-mark-iii-nova-supernova-revised-assembly-instructions-identify-electrode-locations
Channel 1 = IN1N
Channel 2 = IN2N
etc.
I also tried using one channel only, Ch9, and connecting it to the Daisy. But the GUI said everything was Railed or Near Railed. Could this mean I soldiered the Daisy incorrectly or I have defective Daisy?
I think I heard that new Daisy's being sent out are pre-soldered. So that sounds like a wise move. Do you have a "solder-sucker" tool, in case you need to redo some of the pins?
https://www.google.com/search?q=solder+sucker
So just to confirm, you have a Y cable between the Daisy and mainboard SRB2 pins, and then this Y connects to one of the ear clips. The other ear clip goes to Bias on the mainboard.
