OpenBCI and Neuromore readings in hertz amplitudes
I'm currently working on getting the OpenBCI signals processed into hard number hertz amplitude output through Neuromore.
The current issue I'm facing is I don't really understand what it is that is coming out of the OpenBCI parent node and how to process it. I've looked at the default example that detects alpha waves, but I don't see any 'real' numbers passed to any of the nodes in the live graph. (You know, when the links between the nodes display the numbers passed inbetween them)
I have until now used the OpenBCI GUI and understand that what gets read from the hardware is the microvolt (uV) values and the activity is quantified in the electrode region simply by combining the value of the microvoltage data, is this correct or am I misunderstanding something?
What I`m getting under normal circumstances in Neuromore is something like a constant 0.00 - 0.03 from any OpenBCI parent node electrode pin, while in the OpenBCI GUI the normal activity was around 4-6 uV range. I tested the device
For a time I was also under the impression that those same (4-6) microvolt values represented the signal frequency amplitude as well, but now I have some doubts.
What is the process behind converting the input uV values to a hertz frequency?
I have background in programming and I've read quite a lot of academic material on EEG and neurofeedback so I am quite confident in the lingo and the theory of the method, but there is something I feel I am missing with this Neuromore processing software and I'd be very thankful if there was someone who could shed some light on it. Thank you.
