how to read EEG data from Python?
Hi!
I am working with a simple python program to acquire channel data and print it out to console live. But it seems that it does not work. Is it true that all of the 3 bytes per channel has to do with the voltage? Because when I print out channel data and try to blink etc, there is almost no reaction (numbers does not change).
Python Code:
Python Code:
import serial
import binascii
sampNumb = ""
channel_data = [0,0,0,0,0,0,0,0,0]
accel_data = [0,0,0]
gain = 24
Vref = 4.5
# scale_fac_uVolts_per_count = Vref/float((pow(2,23)-1))/gain*1000000.
scale_factor = Vref / (gain * ((2 ** 23) - 1))
i = 0
with serial.Serial('COM4', 115200, timeout = 1,parity=serial.PARITY_NONE, stopbits=serial.STOPBITS_ONE) as ser:
ser.write('b')
while(1):
s = ser.read(1)
if binascii.hexlify(s) == "a0":
sample = ser.read(31)
sampleID = sample[0]
channel_data[1] = sample[1:4] # Data
channel_data[2] = sample[4:7]
channel_data[3] = sample[7:10]
channel_data[4] = sample[10:13]
channel_data[5] = sample[13:16]
channel_data[6] = sample[16:19]
channel_data[7] = sample[19:22]
channel_data[8] = sample[22:25]
accel_data[0] = sample[25:27] # Accel X
accel_data[1] = sample[27:29] # Accel Y
accel_data[2] = sample[29:31] # Accel Z
print(str(int(binascii.hexlify(channel_data[1]), 16) * scale_factor) + "\t" + str(
int(binascii.hexlify(channel_data[2]), 16) * scale_factor))
Any suggestions?
cfausn: Yes, I know C. _I will try to look at your c driver and see what I can learn from that. But is all of the bytes between A0 and C0 representing the voltage? The signal is pretty much random when it is printed out, and there is no response in the frontal electrodes when blinking (as it is in the original OPENBCI GUI). Is any filtering needed you think? Or do you think that this has to do with the fact that the bytes are read wrong due to the A0 bits in the data?
wjcroft: Thank you for that. I will look into the LSL tutorial you linked there, seems pretty useful.
