Best way to get started for games
edited September 2016 in General Discussion
I have the headset all set up and I have ran the GUI and successfully. Now I am just trying to find the most simple project to get started. Does anybody have any recommendations?
  • cfausncfausn Rochester NY
    What are you trying to accomplish? I would recommend checking out EEGHacker's blog and working through some of his ideas in order to get an idea of what you can accomplish with OpenBCI.
    You can also check out my blog if you'd like to work on stuff relating to EMG.
    But the most important part when it comes to starting is to work within the Processing code and familiarizing yourself with how it works. You'll want to do most of your work in the DataProcessing_User.pde file.
  • Thanks for the links! My goal is to be able to use the headset to interface with games that I make. Right now I am learning how to use the SDK and understand the data.
