Arduino Pro mini, broken Internal Test Signal
sss0sohrabsss0sohrab iran,mashhad
edited August 2016 in Other Platforms
Hi. i Just Designed and finished my board (ADS1299 + ARduino Pro
mini(ATmega328) ) and every thing seems fine.i can read and write the
registers and i can get the correct data from noise measurement and
temperature sensor and i can change the gain of the channels but when i
want to set the channels for internal testing they return the positive
data of internal test signal and they don't toggle to negative data.in
other words in any case of test signal, all i get is a DC signal (but i
configure the register CONFIG2 with this 0b11010000) and channels
0b00000101....i don't know why they don't toggle and give me a square
signal...every other thing is normal.BTW i am using external
clock(2.048MHz) for ADS1299 and CLKSEL=0 (tied to GND). thank you for
reading this discussion.(here is a picture of what i get). the data are
in Microvolts and noise is -500uV so i get the correct amplitude of test
signal which in my case is 1.8V
  • sss0sohrabsss0sohrab iran,mashhad
    sorry the correct amplitude is 1.8mV and when i double the amplitude it gives me 3100 microvolts and with that -500 microvolts noise it becomes 3.6mV.
    when i am writing DC internal test signal on CONFIG2 (0b11010011) ,it returns -2500microvolts which i think it is weird and when i double the amplitude it returns -4000 microvolts....is there any explanation?
