Monitoring and recording main physiological parameters with OBCI
Hi guys,
I’m new to biosensing, and need some advice from more experienced community members. My professional area of interest far from Open BCI project, but I had some experience with electronic engineering and simple programming. I’m interested in system for monitoring and recording main physiological parameters like EEG + ECG + blood pressure + video recording. Plus, some kind of alarm system if some parameter will have excessed safe value. I got 16channel OBCI variant and want to use it for my purpose, few question arised:
- 1) If there way for easy extracting pulse value from ECG data or I`ll need additional pulse sensor?
- 2) If there any blood pressure sensors which can be hocked up to OBCI board or it will be easier to use separate blood pressure measurement device?
- 3) What kind of software can be used to have all those parameters in one place? (OpenVibe, BrainBay?)
Thanks
I havent heard of any blood pressure hookups here on the forum, but there are probably a lot of arduino articles,
https://www.google.com/search?q=arduino+blood+pressure
Regarding your pulse questions, some related threads,
https://neurobb.com/t/heart-rate-detection-in-brainbay/28
http://openbci.com/forum/index.php?p=/discussion/352/hrv-heart-rate-variability-algorithms
http://openbci.com/forum/index.php?p=/discussion/316/ekg-analysis-filtering
There is a Search box in the bottom right column.
And if you wanted to avoid the chest strap, you could still adapt Isa @brain 's BrainBay tutorial to neuromore.
One of the links above is to Joel's Pulse Sensor ear clip, which can derive pulse info, there's even new firmware that Joel did with AJ Keller.
