GUI "LIVE Data" does not function / crashes
trimalchio86trimalchio86 Las Vegas
Greetings.
I am having an issue where the GUI crashes when I select to START SYSTEM with LIVE data. The other two data sources work perfectly fine. The COM port is correctly identified by both GUI and Device Manager. FTDI drivers are updated and a '?' sent to the Dongle via Arduino returns the correct code. I also reloaded the firmware on the Open BCI board as discussed below:
Nothing has yet solved this issue so any advice would be greatly appreciated. I am using a 32-bit board with Windows 10. Have not yet installed Daisy.
Thank you
