Init timeout Verify your Serial/COM Port...
I am newer, using an Open BCI board v3 with the ADS1299 chip and am having problems where power it
The port is being recognized as COM5 and the dongle has a steady blue light when I plug it into computer. I have the dongle set to gpio6 as normal. I run the OpenBCI_GUI in Processing and then the program opens, and I can click COM5 from the serial ports menu and then when I click "Start System" it tries to initialize communication with BCI Board and then it gives me
"Init timeout Verify your Serial/COM Port Power DOWN/UP your OpenBCI & USB Dongle Then retry Initialization"
My PC OS is windows 8,
the board is 32bit
the step like this:
1.plugin dongle
2. run OpenBCI_GUI
3. switch to pc to power board
4. Start System
the led on board blink always not 3 times
If anyone could help me out it would be much appreciated! Thank you!
