OpenBCI_GUI Linux, window goes blank
I just received the 8-channel / 32-bit kit and am keen to start getting some data out of it. I followed the Getting Started guide here .
When I launch the GUI it works fine with the synthetic stream of data. However when I try to use the hardware the UI hangs after I click "Start".
It doesn't consume any resources, it just sits there displaying a black rectangle on my X session. There are no window controls to minimize, close, etc., so I have to kill it via the bash shell.
It does create a session data file, but the file only has a few strings of header information and no actual data.
Thus, it seems there's a communication problem.
Here's the output of dmseg | grep FTDI
[ 6500.722621] ftdi_sio 2-2:1.0: FTDI USB Serial Device converter detected[ 6500.722997] usb 2-2: FTDI USB Serial Device converter now attached to ttyUSB0
So the system sees the dongle. I can't really tell if the dongle sees the BCI board, however. I noticed during setup that the TXD LED on the dongle (red LED) only blinks one time when the BCI board is turned on, unlike the 3-blinks that the Getting Started guide says should happen. I suppose this might be related.
Any ideas on how to proceed from here?
-Elliot
Here's a related post on permissions, for those Linux users interested,
http://openbci.com/forum/index.php?p=/discussion/597/fixing-linux-write-permission-for-dev-ttyusb0
I've managed to installed processing n it was way to shit processing but it didn't help me to run OBCI gui interface help me how to do it
I merged your question into this existing thread. It sounds like you have a permissions problem on your dongle tty device. Check the previous links.
Windows users have seen blank screens when the display driver needs updating, but it sounds like your issue is with the /dev permissions. Has this laptop worked previously with your OpenBCI, or is this a new laptop?
seriously man i tried everything i even bought a laptop dell Inspirion 15R N5010 but gui still not working
Laptop: Dell Inspirion N5010
Windiws 7 Ultimate
i5 processor 2.66 GHz
Ram:2GB
64bit
What should i do, whenever i run the gui
it shows this gray screen...no buttons no nothing please help me
