Board_Defs.h: No such file or directory
I'm on linux 64 bit. I've done the following.
# Downloaded arduino
wget https://www.arduino.cc/download_handler.php?f=/arduino-1.6.9-linux64.tar.xz
tar -xvf arduino-1.6.9-linux64.tar.xz
# Downloaded libraries
git clone https://github.com/OpenBCI/OpenBCI_32bit_Library
mv OpenBCI/OpenBCI_32bit_Library/OBCI32_SD arduino-1.6.9/libraries/
mv OpenBCI/OpenBCI_32bit_Library/OpenBCI_32_Daisy arduino-1.6.9/libraries/
# Downloaded chipKit
wget https://chipkit.s3.amazonaws.com/chipkit-core/builds/linux64/chipkit-core-linux64.16778024.41ae417.zip
mv chipkit-core arduino-1.6.9/hardware/
# Checked that I have hardware/chipkit-core/pic32
cd arduino-1.6.9/hardware/chipkit-core/pic32
pwd
# /home/jon/library/projects/openbci/arduino-1.6.9/hardware/chipkit-core/pic32
# Going back
cd -
cd arduino-1.6.9
# Starting IDE by opening the .ino file
./arduino ../OpenBCI_32bit/OpenBCI_32bit/OpenBCI_32bit.ino
Then when ide shows up I click on Tools-> Board and select "OpenBCI 32"
Tools -> Port -> /dev/ttyUSB0
It fails during compilation with this error:
In file included from /home/jon/library/projects/openbci/arduino-1.6.9/hardware/chipkit-core/pic32/cores/pic32/WProgram.h:9:0,
from /home/jon/library/projects/openbci/arduino-1.6.9/hardware/chipkit-core/pic32/cores/pic32/Arduino.h:4,
from sketch/OpenBCI_32bit.ino.cpp:1:
/home/jon/library/projects/openbci/arduino-1.6.9/hardware/chipkit-core/pic32/cores/pic32/pins_arduino.h:263:24: fatal error: Board_Defs.h: No such file or directory
compilation terminated.
exit status 1
At this point I don't even know where to look, because I've tried everything. Even downloaded test release chipkit. Pretty much stuck with old firmware until I'm going to be old and die. Any ideas of what that could be?
pwd
# Going back
cd -
cd arduino-1.6.9
exit status 1
Tried using Arduino 1.6.7 instead of 1.6.9, same error.
Tried test build 2015-09-03 on 1.6.7, same error.
Have you looked through these threads,
http://openbci.com/forum/index.php?p=/search&Search=Board_Defs.h
http://openbci.com/forum/index.php?p=/discussion/208/chipkit-uploading-tips-restarting-bootloader
http://docs.openbci.com/tutorials/02-Upload_Code_to_OpenBCI_Board
Yes. I've tried using ~/Arduino now, instead of using the directory where arduino binaries are (which also has libraries and hardware folder). Same effect, just different paths:
Arduino: 1.6.9 (Linux), Board: "OpenBCI 32"
Build options changed, rebuilding all
In file included from /home/jon/Arduino/hardware/chipkit-core/pic32/cores/pic32/WProgram.h:9:0,
from /home/jon/Arduino/hardware/chipkit-core/pic32/cores/pic32/Arduino.h:4,
/home/jon/Arduino/hardware/chipkit-core/pic32/cores/pic32/pins_arduino.h:263:24: fatal error: Board_Defs.h: No such file or directory
#include <Board_Defs.h>
exit status 255
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
➜ Arduino find ./ -name 'Board_Defs.h' | grep openbci
./hardware/chipkit-core/pic32/variants/openbci/Board_Defs.h
➜ Arduino cp ./hardware/chipkit-core/pic32/variants/openbci/* /home/jon/Arduino/hardware/chipkit-core/pic32/cores/pic32/
I've seen this: http://openbci.com/forum/index.php?p=/discussion/598/openbci-32bit-compile-error-plib-h-no-such-file-or-directory
So, I've commented out: /* #include plib.h */
in /home/jon/Arduino/libraries/OBCI32_SD/utility/Sd2Card.cpp
Now, it's yelling at me showing same errors which are shown in that thread on plib file. I'm tying to figure it out, because I haven't programmed in C++. But I'm slowly making progress. This rabbit hole goes deep.
/home/jon/Arduino/libraries/OpenBCI_32_Daisy/OpenBCI_32_Daisy.cpp
1001: byte inByte = spi.transfer((uint8_t)0x00); // retrieve data
1018: inData = spi.transfer((uint8_t)0x00) | (spi.transfer((uint8_t)0x00) << 8); // get the data and arrange it
Similarly, I had to do the same thing with "/home/jon/Arduino/libraries/OBCI32_SD/utility/Sd2Card.cpp", looking at which lines it complained and adding (uint8_t) there to have explicit cast.
This solved the cast errors, but it still showed one more error afterwards:
"/home/jon/Arduino/hardware/chipkit-core/pic32/variants/OpenBCI No such directory"
I've looked there and there was "/home/jon/Arduino/hardware/chipkit-core/pic32/variants/openbci", so I copied it (probably rename would be fine) to create "/home/jon/Arduino/hardware/chipkit-core/pic32/variants/OpenBCI"
Now, it's time to upload it. If it fails, I'm gonna throw my notebook out of the window, buy a sheep and go live in mountains of Tibet.
@wjcroft I don't think this issue (Board_Defs.h, etc) was caused by me installing something terribly wrong. Something is clearly broken with the code from chipkit or repos in http://docs.openbci.com/tutorials/02-Upload_Code_to_OpenBCI_Board One has to modify code to make it work, also it expects folders to be named one way, but they are named another way (E.g., OpenBCI_32 vs openbci). I'm not sure whether this is Linux specific or if it's universal. Based on types of errors I suspect it may be the latter. So, perhaps, as a temporary solution we can put some disclaimer in the docs, to threads like this and plib. Because at it is now things from the guide don't seem to work together at all. If this is indeed not me screwing something up, then I can create a pull request on docs repo with a small (linux?) disclaimer like "If you see Board_Defs.h" look this way and a link to this and plib threads.
