"does not exist" in ControlPanel.pde with Chip's hexBug EEG_Processing.pde
I'm trying to read in EMG signals using the OpenBCI and electrodes with electrode paste, and then analyze these signals to detect a "peak" - where the EMG signal is strong enough to count as muscular motion as opposed to just noise from the BCI board. I modified the default EEG_Processing file using code from:
However, when I try to run the modified version, I get the following error:
Line: cp5.get(MenuList.class, "serialList").setVisible(true); //make sure the serialList menulist is visible
Error: The function setVisible(boolean) does not exist.
This is occurring in ControlPanel.pde. I looked at a previous thread in which this same problem was mentioned, ensuring that my controlP5 library is installed correctly and in the proper location. I even installed alternative versions of Processing and re-installed OpenBCI GUI to try and fix this. Any help would be greatly appreciated!
https://github.com/OpenBCI/OpenBCI_Processing
If so, then extrapolate from the controlP5 library setup there, to your situation with Chip's old sources. You may need to shift some things around.
