Stream to OSC and use Processing GUI at the same time?
soundingsounding boston
Hi all,
I would like to stream to OSC using the Python plugin,
but also be able to visualize the signal using the Processing GUI at the
same time. Is there a way to route the signal to do this?
    Use the search box at lower right for LabStreamingLayer. By outputting a named stream it should be possible to send to any number of LSL input devices. While OpenBCI_GUI does not currently consume LSL streams, LSL provides a stream viewer program.
  • Thanks-- I'm familiar with the LSL's vis_stream, but was hoping to use OpenBCI's for a public presentation as it's much more attractive... would be nice if the OpenBCI GUI could take an LSL  or OSC stream as input.
    I believe neuromore can output and consume OSC streams, it has VERY featureful GUI presentation graphs.
