OpenViBE Acquisition Server (motor imagery), montage, configuration
I am trying to run the mi-csp scenarios of openvibe on windows 8.1.Can anyone please let me know the COMPLETE steps of the following queries:
1-how to set the new openbci driver in openvibe for 5 electrodes: Pz[bias], Cz, C3,C4, A4 positions, using 32bit openbci board?
2-how to save a raw signals file of these 5 electrodes in mi-csp-1-acquisition.xml? Please no NOT refer me to any tutorials made BEFORE the openbci driver was integgrated into the openvibe acquisition server.] ----thank you.
http://blog.jfrey.info/2015/03/03/openbci-motor-imagery/
http://openbci.com/community/openbci-crossing-swords-with-motor-imagery/
With that @ reference and email notification, Jeremy may comment here. There are also some tip on the AS setup on these threads,
http://openbci.com/forum/index.php?p=/discussion/206/openvibe-p300-speller-tutorial-questions
http://docs.openbci.com/research tools/OpenViBE
http://openbci.com/forum/index.php?p=/discussion/326/openvibe-v1-0-now-supports-openbci
.ovextension will be created in thesignalsfolder next to the scenarios files.'----the file DOES NOT get saved!!!!What to do?Did you look at the OpenViBE documentation on the AS?
https://www.google.com/search?q=openvibe+acquisition+server
Wouldn't you just check "Select only named channels"?
This is with reference to the post http://openbci.com/community/openbci-crossing-swords-with-motor-imagery.
I have 8 channel OpenBCI V3 board. I wish to implement the motor imagery exercise (Open BCI + Vibe) using this board without daisy chain module. Please guide about the positions of remaining electrodes other than C3 and C4.
Thanks for your time.
Azhar
Azhar
Jeremy's @jfrey post does already show two montages, one that requires 16 channels, the other will work with your 8 channel board. He points out that the 16 channel montage is optimal for the resolution that is needed. If you go with less channels on the first setup, you may find it harder to achieve the results.
Have you looked over other possible MI montages?
https://www.google.com/search?q=bci+motor+imagery+montage
[Figure 12. The best configuration with 8 electrodes given by Hoffman et al. (Hoffman et al., 2008), (Hoffman et al., 2009).]
http://www.intechopen.com/books/intelligent-and-biosensors/signal-processing-and-classification-approaches-for-brain-computer-interface
http://infoscience.epfl.ch/record/101093/files/manuscript.pdf
[section 4.2]
http://sccn.ucsd.edu/~yijun/pdfs/EL07.pdf
Hi, sorry I will answer in a hurry (...as usual I think if you check my history
