Daisy module signal amplitude incorrect when saving to SD card
I'm using the 32bit OpenBCI 16ch kit. I am recording all 16 channels with a single ground and reference that are connected to both the main and daisy boards with a y-cable. When saving the data to the SD card, the amplitude of the signal recorded on the daisy channels (9-16) are ~45 times higher compared to the channels on the main board (1-8). This does not happen when I am streaming the data wirelessly to the computer (i.e. both the GUI and saved data file have the correct amplitudes). I received my board a couple months ago, so it should be running the latest firmware. Does anyone else have this problem?
