seeking EEG file recordings, to download and test with
Is there any place where I could download signals registered with OpenBCI?
I mean text / csv files.
I want to watch them and test openvibe or neuromore.
http://physionet.org/
This utility allows conversion between formats,
http://www.teuniz.net/edfbrowser/
If you are talking about the raw format that is received from the dongle serial port, then I know of no current programs that save that directly. Although you should be able to use the OpenBCI_Python code to create such a file. The drivers in programs such as BrainBay, and neuromore, expect to read directly from such a serial port. On Windows this is a COMx: device. On Mac, a /dev/xxx file. On Mac and Linux it's easy to substitute a file stream for a device or serial stream. However all the programs will also be attempting to setup baud rates and other parameters for the port, which only make sense on real serial ports. You might look around for some setup that will let you emulate a hardware serial port from the contents of a file.
http://openvibe.inria.fr/supported-file-formats/
Does anyone know of raw EEG reference data available, showing eyes-closed alpha waves, SSVEP, or other basic conditions that should produce clearly visible phenomena? I'd like to try running it through my FFT transformation and visualized to test whether the system is working correctly. Thanks.
https://www.physionet.org/physiobank/database/#neuro
http://openbci.com/forum/index.php?p=/discussion/comment/2970/#Comment_2970
Hi
I merged your question into this existing thread. See previous posts. There is also a search box in the right column and "recordings" would have returned this thread. Thanks,
On the occasion of the Brain Week I would like to tell my facebook friends etc. to download the OpenBCI GUI and load a file for playback. Is there a file I could use?
At this thread further above, Joel @biomurph says in 2015:
"If you download the OpenBCI GUI (or just go to the github) you will find that we have some pre-recorded data in the program file."
https://github.com/OpenBCI/OpenBCI_GUI/tree/master/OpenBCI_GUI/SavedData/Sample_Data
(end of quote)
At the latest version of the GUI (December 2017) the Saved Data folder contains only recordings saved by me and I could playback those.
The EEG_Data folder contains the SDconverted-2016-12-17_18-28-40.txt. which is of 0 bytes (OpenBCI_GUI/application.linux64/data/EEG_Data/).
From the files in Github mentioned, I tried the SDconverted-2014-10-22_16-27-06.txt but it is impossible to playback:
OpenBCI_GUI: initSystem: loading playback data from /home/elisabeth/Documents/SDconverted-2014-10-22_16-27-06.txt
%OBCI Data Log - 2014-10-22_16-27-06
OpenBCI_GUI: initSystem: could not open file for playback: /home/elisabeth/Documents/SDconverted-2014-10-22_16-27-06.txt
: quitting...
OpenBCI_GUI: stopRunning: stop running...
java.lang.NullPointerException
at OpenBCI_GUI.initSystem(OpenBCI_GUI.java:675)
I presume that is due to difference in data structure (mentioned file below followed by my file):
0.0,84022.69,84056.17,84118.64,84162.945,84132.52,84083.55,84091.04,84070.945
1.0,84054.07,84087.62,84150.07,84194.33,84163.91,84114.93,84122.484,84102.37
2.0,84121.63,84155.164,84217.66,84261.94,84231.43,84182.43,84190.08,84169.914
%OpenBCI Raw EEG Data
%Sample Rate = 200.0 Hz
%First Column = SampleIndex
%Last Column = Timestamp
%Other Columns = EEG data in microvolts followed by Accel Data (in G) interleaved with Aux Data
0, 62.35, 74.37, 77.09, 72.42, 0.000, 0.000, 0.000, 21:24:14.251
1, 14.71, 14.76, 13.00, 12.93, 0.000, 0.000, 0.000, 21:24:14.265
2, -22.81, -26.63, -33.35, -33.58, 0.000, 0.000, 0.000, 21:24:14.266
Would you consider placing a file for playback in the next GUI release? In the mean time could you recommend a file that we could link to in a facebook post etc.? I think it would be a good idea for the general public to familiarize themselves with an EEG file and then maybe try to create one themselves!
Thank you in advance
Best wishes
Elisabeth
