Multiple device setup and bias
Hi
This page is awesome! Fantastic work.
I'm designing af 32 channel (also ref and rld) electrode impedance measurement tester for some electrode caps used for research. It is going to be used for checking impedance before actually moving the patient into a MEG scanner where an commercial scanner takes over (no impedance check).
What mode should I use? Daisy or Standard
How do I setup the bias hardware in these modes?
Or should I just add 8 (4:1) multiplexers on the 8 inputs of a single ADS1299?
best regards
Martin
Thanks for your comments. I think I will try the multiplexer solution. I'm also a little nervous about low-level signals and multiplexers but there is a first time for everything. Something like analog devices ADG759 with 100 p leakage current and 3 ohm on resistance might do the trick.
Martin
you can try to connect all your ADS1299s to one SPI bus but give each it's own CS pin on your micro. That way you can access them separately.
Ferdinand
I'm aware of this, but how do I handle the bias in this setting? Can I use the bias on the first chip while measureing impedance on the third chip?
Martin
so you want to use the lead-off detection mode to measure the impedances of your electrodes, right? In that case you should be fine with just one BIAS connected.
Regarding the bias I suggest you take a look at page 53, figure 51. Basically you can just connect the BIASINV pins of all devices together, but you have to power down all but one amplifier. For this to work you have to either
Also, if you're just doing impedance measurements I would suggest you take a look at the ADS1298. Its specs are a little worse than the ADS1299's, but it's less expensive.
Ferdinand
---------- Forwarded message ----------
Date: Fri, Dec 20, 2013 at 7:42 AM
Subject: Re: your ADS1299 impedance measurement solutions
To: K
Cc: William Croft, Chip Audette, Conor Russomanno, James Cotton
Hi K,
Yes, you're right. The Daisy-Chain implementation that allows for control of all cascaded devices via individual CS pins is much more versatile configuration. In our first cascaded design, we had to work with the Daisy_In to D_Out setup because we could not 'see' the individual ADS CS pins through the isolation barrier. Our design for the 16 channel system will use the cascade design instead of the daisy design.
The data sheet says that using START pin is recommended with this, however we will also test sending the START SPI command to synchronize them. Have you tried this?
Joel
I developed a 24 channel daughter board with three ADS1299 in cascaded form ... making CLK Sclk Din Dout Reset pins shared with all ADS of daughter to mother BCI board.. and allocating separate CS pins from microcontroller. ... and BIASINV is also commen for all ADS chips... the designed project is working but from daughter board it doesn't gives me the desired signal ... can any one help me that where is the problem...???
http://openbci.com/forum/index.php?p=/discussion/504/expand-from-16-to-32-channel
Because The BIAS IN and Out and BIAS_INV are all connected to the amplifier internally so daughter board's BIAS_INV(which is connected with mother board) will also have comes from the BIAS IN and OUT. This is little bit confusing me .
Thank you alot for your answers Its really appreciating and I'm learning more from you.
I want to share the picture of my designed board but don't know how to attach image here, ther is no such button
Thanks @wjcroft
https://fhscript.com/Dm4/10603436_1550106501981676_6228247410065775798_n.jpg
This is what actually confusing me
http://openbci.com/forum/index.php?p=/discussion/172/understanding-bias-signal-generation
