Ultracortex Mark III Feedback & Mark IV Priorities
Hi everyone,
I want to start this discussion regarding:
- Issues w/ printing & assembling of the Mark III
- Feedback/suggestions on assembly guide & the Mark III design
- Design priorities for Mark IV
- Other 3D-printed headset conversation topics
This thread will heavily influence the design priorities of the Ultracortex Mark IV, from our ongoing Kickstarter campaign.
The current assembly guide suggests choosing a single 10-20 electrode site placement layout, then custom cutting the electrode leads to match. If the user then needs to change the layout (say for another BCI or neurofeedback requirement) -- it's possible that some of the shorter electrode leads may no longer reach their new 10-20 sites.
Some mention of this in the guide might be helpful. Possible solutions may be to leave the leads longer, then use twist ties or tie wraps to coil (or zig zags) to take up the slack. Another approach may be to have some extension leads handy if faced with a short lead. Adafruit has these available in 3", 6" and 12" lengths. The links at the end of that page also show other jumper leads sets available. These could be handy if the user does not want to sacrifice their cup electrodes.
For the Mark IV kit we will likely ship the kit with only enough electrodes to run the 8-channel setup, and we will offer a cheap, add-on kit for targeting more locations. The standoff nodes (without an electrode) will be redesigned with a semi-spherical, soft tip and roughly a dosen of these will come with each Mark IV kit.
Instead of using sandpaper and sanding everything by hand I found two attachments for my Dremel which made that job super quick and easy.
I also used paper tags to label each electrode. My only piece of feedback would be to modify/enhance the charging method for the LiPoly battery from Adafruit. I'm a little worried that the plastic will wear down so I'm using 2 screws instead of 4 to hold the board in place. I'm not sure what they're called but I thought perhaps those plastic pieces that are used to hold heatsinks in place might work well.
Corey
A comment from John Pellman on the OpenBCI/Ultracortex Github Repo: "
-- High Density EEG --
This might be more of a suggestion for a future project than an improvement on the present iteration of Ultracortex, but I thought I'd throw it out there anyways.
A small, but growing, number of researchers are scanning with 32, 64, 128 and 256 electrode systems in order to employ a technique called source localization. Source localization, as its name implies, allows you to pinpoint where EEG signals are coming from in a way that gives spatial resolution reminiscent of fMRI (though not comparable; fMRI voxel sizes can be as low as 1 mm isotropic, while EEG voxel sizes tend to be around 5 mm isotropic). This technique, though not without controversy (what scientific methodology isn't?) is something I would be interested in seeing become more prevalent, as it seems to me that it would be much more cost effective to gather large datasets with EEG than with fMRI.
There are some high density nets on the market today, and while they're cheaper than fMRI, they can still be rather pricey (upwards of a thousand dollars per net). In a time of dwindling scientific budgets, these costs can be prohibitive to some labs that otherwise might have wanted to try using this technique. In light of this, I think that it would be neat if there were an open source alternative that labs could try out (even if it weren't necessarily as fully-featured as the nets that are out right now).
Here are a couple links for you to check out concerning source localization if your interested: edu/content/publications/LATN/ BookChapters/Pizzagalli_ HandbookPhysiology07.pdf brainstorm/Tutorials# Background_readings
http://cdasr.mclean.harvard.
http://neuroimage.usc.edu/
http://openbci.com/forum/index.php?p=/discussion/592/connector-housing-wear-after-many-rechargings
McKesson 61-84344. Here is one site carrying them, with photo. I got a pack of 10, which can be cut into many squares or disks.
Amazon also carries, as well as other online stores:
https://www.google.com/search?
As far as the saline solution, the more dilute, the less harsh the sensation. As these guys documented. I'm using about a 60 mMole solution. Just a tiny tiny amount of KCl in 100 ml of water.
http://dx.doi.org/10.1016/j.
Conor
I assume you guys are considering the flexible Ninjaflex filament for some applications such as bumpers or couplings. Another possibility would be as "softeners" for the FRI combs, in those cases where certain users feel them on the scalp as too "pointy" during long sessions.
So I'm envisioning little Ninjaflex 'pads' that have an inverse hole pattern to match what is on the combs. These can friction-fit over the combs and thus offer some cushioning effect. They could be printed in various thicknesses or "textures" (surface patterns) that could provide various degrees of softening of the perception of the FRI comb pins on the scalp skin.
If you've seen this stuff you know that it can be made more or less "squishy" by how many voids and cavities are inside the interior. Thinner walls and more voids create an object that is softer than one that is printed as a solid block. Softening of the Ninjaflex could also be achieved by using a surface texture such as ridges or comb teeth.
http://openbci.com/forum/index.php?p=/discussion/comment/3821/#Comment_3821
Joel @biomurph and @Conor did some earlier test print combs from conductive filament. But the filament material was of too high resistance. (It required gel injection to get a good connection.) This new graphene filament may solve that. And since it is also stronger / smoother, may allow comb shapes that are analogous to the splayed design of the Cognionics combs. That is, comb tines that bend / splay out a bit as they contact the scalp, thus providing some adaptive qualities to scalp surface variations.
