connector / housing wear after many rechargings
I have the Ultracortex and the 16 channel board. I also installed the recommended battery for the unit. Is there some way to recharge the battery without removing the battery and the entire housing? I have done so once, and the second time the process of removing the battery connector from the board despite my careful attention weakened the connector to the point where I had to replace the female battery connector. In addition, I can tell there is not enough strain relief to prevent damage from continually inserting and removing the battery to recharge it. I probably missed it, but is there a location on the board to insert connectors or wires that are not part of the battery assembly and connector to use as a “port” to recharge the unit?
