Weird symbols at the end of files written on SD card
When I tested the function of writing OpenBCI data to the SD card, I met some following issues
1. The .txt files I received always have weird symbols like "up-side down hat" added to their end
2. There is no footer written at their end as shown in the documentation
Has anyone had these issues so far?
3. When I increased the sampling rate of the board to 1000Hz, I expected that the data should be written to the SD card faster than transferred via bluetooth connection and written to the PC. However, when I compared these two files (one written to the SD card and one written on the PC), they have the same number of samples recorded. It meant that the writing speed cannot be fast even though the data was written to the SD card.
Is it possible to increase the writing speed of the board to the SD card (in case of 1000Hz sampling rate) if it runs the modified firmware of writing to the SD card only provided on Github?
Has anyone tried it?
In my test, I used the SanDisk Ultra 64Gb microSDXC class 10 formatted in FAT32.
@ntland,
1) the files that you receive by bluetooth or from the SD card ?
2) On the SD card the Footer is written in the last block of 512 octes, which is filled with zeros.
3) When you choose a "record duration" in fact the soft chooses a number of block, not a duration... So the files that tou receive has always the same size independently of the sample rate... At least on the SD card...
Yannick.
To write one-second data , at 250Hz or 2kHz , it takes one second. (Joke).
When you choose to record at 250Hz for 5 minutes you record 11000 blocks...
at 2k of coarse it will take about 5'/8 or 300 secondes / 8 ... to get these 11000 blocks
Find this define in the soft :
#define BLOCK_5MIN 11000
Yannick.
no, no.
5 minutes corresponds to 11.000 blocks at 250 Hz.
That should do 37.5" at 2k Hz.
at 2k Hz it is 8 time faster and shorter. to acquire these 11.000 blocks
A block = 512 octe,
in the 5mn_file you should find about :
5x60x250 lines of 75 chars (if you uses accel and auxilary data, else less),
5x60x250x75 == 11000x512
Yannick.
Do not worry Anh, 8 times faster and shorter @ 2kHz, is well related to "the speed of writing the data from the Board to the SD card."
Yannick.
